lexus and 440's is not a bad idea if done properly. Just throwing the lexus on a car with 440's is a very bad idea and will cause the motor to run lean. But with an AFPR and SAFC a lex with 440 setup will work just fine but needs to be tuned. If do not want to tune, change fuel pressure etc. then go lex with 550's and call it a day. This is close enough that the stock ecu should be able to compensate for any differences (lex is 25% bigger in area, 550s 25% bigger in fuel flow) so same ECU signals are generated just with the ability for more power. To get the most out the 550/lex combo you will need an AFPR and some fuel tuning device though along with the all important wideband.
My car running stock afm/440s/fuel pump/pressure reg. also runs pig rich above 3k rpm's, AF's about 10.5 to redline @ 12 lbs of boost.
