Sounds like you want to just plug and play. No. It's not like dropping in a replacement like-for-like engine - the M and JZ series are different, totally. You'd need a custom harness made up to mate the 2JZ electronics & ECU to the body electrics. Regardless of the type of 2JZ it is - physically, it'll fit, with the right mounts & crossmember (you need an 89+ crossmember with round mounts to fit a JZ) but obviously you'll need supporting mods...like fuel pump, transmission bellhousing etc.
