whitemike;1478189 said:Are you guys saying the electronics are the same and it's just the physical housing that's different? Or do you mean something way different?
-Mike
IJ.;1478190 said:Correct
Kai;1478414 said:The Lexus AFM is 25% larger than the stock AFM in the Supra. However the ECU only read it as the stock size - so if you increase the size of the AFM by 25%, you need to increase the size of the injectors 25% to match it. Otherwise, you'll run lean and turn your piston into a plasma cutter...
MKIIINA;1477805 said:the 550cc injectors are either from an FC RX-7...
7M-KDL;1478421 said:it turns your combustion chamber into a plasma cutter doesnt it? as it cuts/melts the piston
