If you add the Lexus AFM without increasing the fuel injector size, you're shovelling in 25% more air without the corresponding match for fuelling. TCCS expects 440cc injectors, and its regular AFM. The lexus trick works with 550cc injectors because the AFM housing is 25% larger (550cc = 440cc + 25%). If you increase fuelling without air, you run rich, and get bore wash. You increase air intake without increasing fuel, you run lean and run the risk of turning your combuston chamber into a plasma cutter. Doesn't matter how much you trim it out on a piggyback, you're STILL GOING TO BE RUNNING LEAN.
Whats the point of telling you people how things should be done, explaining WHY and the pitfalls of it, if you insist on half-assing it because you somehow magically 'know better'?
DO IT PROPERLY OR DON'T DO IT.
