Lex/560s wont go rich even with lots of fuelpressure and safc tweaks
WillWorkFoBoost
that guy
Sep 1, 2009
130
Maine
GrimJack;1753970 said:
Another thing to add to the pot. Your TPS only reading 70% is likely fine - I suspect that your SAFC is displaying throttle percentage based on a 5v scale, and all the Toyota TPS's I've checked are WOT at ~3.8v, not 5v.
Weird? It used to be 0 at idle, 100% at full throttle. Now its only 68% and has tps code. for a year it was 100% at wot, 0 at idle and was fine.....
san supra
833
san antonio
there was an write up on here on how to install and set up your lex/550.
maybe that could clear some basic things up? i cant find it to help...sorry
Base fuel pressure is what your setting with the afpr. Spec is 33-40 psi. It will be rising rate so for every psi of boost the for will add 1 psi of fuel pressure.
digihonk82
118
Olathe, KS
send me your wideband and safc and ill play with it for a while on my car that has the same inj. and afpr and lexus maf doing some fun tuning stuff, driving in the hot summer pick up some chicks with my new electronic devices and ...wait a second thats cool with you right?
