Backup camera installed. I used a very compact AOSILEY Camera with 170 Degree Wide Angle FOV. Ordered from Amazon and installed into the top of the center taillight recess for the license plate. The camera came with the required hole saw which was nice and I used a right angle drill adapter because space is tight. I had to remove the right and center taillights to get access for the install and wiring. Since I already tapped into the backup light circuit at the HU, I only needed to ground the camera.
I used the existing LHS grommet for the backup lights to route the camera cable inside the car by drilling an extra hole in the grommet.
The end result turned out great. You will not notice this camera unless you go looking for it.
