Lefty loosey...right?
paradox616
472
Melbourne, Australia
Kevin;1570810 said:
lefty loosey is right. and yes 160 ft-lbs is not enough. i used an electric impact gun. held on it for about 10-15 seconds and it cranked free. iirc its torqued on to like 195ft-lbs so ya lol
try the starter method.
I've mangled big breaker bar against the ground with the starter method on my daily, make sure you pull the EFI fuse, last thing you want is the motor starting with the balancer loose....
on my supra i put the car in gear to lock the crankshaft and undid the bolt with a big breaker bar with a pipe on it, you can't do this on a auto.
mk3-4-me
669
Milwaukee, WI
i had to heat mine up with a plasma torch till it was red hot before i could loosen it with a torque wrench.... those things get super tight dude...
shaeff
Kurt is FTMFW x2!!!!
10
Around
thedave925;1570542 said:
It must be on a stand if he's use an impact gun...
IwantMKIII;1570808 said:
not really, just remove the rad.
This.
Dirgle;1570812 said:
Umm, wow some people need to reread the original post. He never mentioned the ft-lbs used. He said he used 160 psi on the impact gun. If it's a good gun of decent size it could be a considerable amount of torque, then again if it was a Walmart special, it might not even do 100 ft-lbs.
160psi on a decent impact gun is really cranking. Either A) get a new impact gun, or B) you have the world's strongest crank pulley bolt.
Hopefully you replaced that bolt and damper?
supramk3speed
305
Texas
The motor is in the car and the impact gun wasn't a peace o' crap walmart 125 ft lbs of torque special (the first one i used was a harbor frieght special!), but i have had no luck. Im going to try the starter method, i hope it works! I hope i haven't removed anything that will keep it from "starting". I was wondering, will it move the crank pulley quick enough to lose TDC to a large extent?
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
if the cam gears are also reset to tdc and the crank is tdc you wont be on the wrong stroke. make sure the #1 piston is all the way up (check in the spark plug hole)
supramk3speed
305
Texas
Oh! okay. Thanks for the help:icon_bigg
