So I've finally gotten close enough in parts i thought i would start a build thread. Not only will this help keep you guys informed but it will help keep me on track. In the end we will reach a major payoff that everyone will enjoy.
So stick around check out the pictures and stories. I'll be updating my To do list every so often along with pictures. Maybe someone might be able to help me with a part sourcing along the way.
To do list: Completed
To buy list: Purchased Items
Engine Build:
Teaser Install:
Still more to come LATER tonight!
Thanks,
- Rebuild Engine
- Engine / Transmission mounted
- Wiring
- Fuel System
- Turbo Oil lines/ Oil cooler
- Inter-cooler piping
- Exhaust
- Tuning
- 2JZ-GTE
- Front-Sump oil pan
- Eagle H-Beam connecting rods
- JE forged pistons (Standard 8.5:1 .20 over)
- Cometic 2.0mm MHG
- PT74GTSHP
- Turbo manifold
- Waste-gate
- Aftercooler A.K.A "Intercooler"
- TAiL 50mm Blow Off Valve
- Titan motor-sports Fuel Rail duel feed 8an/6an return return
- Titan motor-sports 1600cc (151lb domestics) injectors
- Aeromotive A1000 8an in/6an out
- Aeromotive A1000 w/ pre and after filter
- Clevitte bearings set
- Main bolts
- Oil squirters
- Oil Pump
- Water pump rear housing/Meizure electric water pump
- Complete timing belt setup
- Complete serpentine belt setup/tensioner
- Alternator
- PS pump/Reservoir
- Haltech E6A EMS
- MSD DIS-4
- R154
- 1JZ bell-housing
- 1JZ clutch and flywheel setup
- Drive-shaft
- Engine mounts MrTechNic
- Mk.II Auto tranny mount
Engine Build:
Teaser Install:
Thanks,
