Poodles;1948796 said:They're not going to dim nearly as well as it's not the proper way to dim LEDs (which is PWM, and there's ways to retrofit it)
Ok, had to look up PWM (basically flicker really fast, with longer off to make dimmer, right?)
The problem with dimming by voltage (normal) as I read it is that the extra voltage gets absorbed by the regulator and converted to heat - is there some way to shunt different levels of voltage to some dummy load instead? Like a small heater (useless for heating anything...) or something? so instead of the regulator absorbing the extra voltage, it just redirects to a heatsink type arrangment?
Please be gentle - I'm an electrical idiot, but I'm trying to learn.
