Leaky hatch? Look here!
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
So, my hatch was leaking. I'm sure anyone reading this is familiar with the symptoms - pop hatch, lift, water has been pooling in the plastic body panel that covers the rear window wiper motor, which promptly pours out the sides. Usually one of them manages to pour into the hatch, getting your stereo equipment wet, covering your first aid kit with mildew, and making your spare coolant / oil bottles slimy.
I replaced all the obvious stuff. Hatch seal, rear tail light seals, every spoiler seal, antenna seal, wiper seal, you get the idea. No dice, damn thing still leaks.
So, it must be the actual glass seal, I figure, which is a tin plated bitch to get at, and isn't a rubber seal, it's glue like the windshield. So I pull off the glass trim - which wasn't easy by any stretch of the imagination, and the side pieces both get trashed in the process. Clean the crap out of the crack along the top and upper sides of the glass and wait several days with the car in a warm garage until it's utterly dry. Then I silicone the top and about the top 4 inches down each side.
While waiting for this to dry, I figure I might as well pull off the bottom trim as well... after some digging, I realize it's bolted on. I start to get suspicious... pull off the nuts, pull out the trim, and sure enough, it's obviously been leaking through those holes, they are surrounded by dirt and gunk that's built up over time.
So I clean the dirt and gunk out of there, and as a test, just put tape over those holes - have to wait for new glass trim to be sent anyway.
Been driving it in the rain for two days now... rear hatch is still bone dry.
So, on the one hand, WOOT! Problem fixed.
On the other hand, it was probably just that lower trim, and I could have fixed it in 10 minutes by pulling just that piece and applying silicone to those holes. Something to keep in mind if you have the same problem.
Like lower trim that says turbo or toyota supra?
Lol ive always thought about that but never took the time to investigate. Dont get much rain.
BigKO
326
Riverside
Hmm I think he meant lower trim on the hatch glass, because that seems more likely to leak into the plastic cover than the body trim with lettering on it. I could be wrong though...
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
You are correct. The trim piece that goes across the bottom of the glass.
BigKO
326
Riverside
Yeah that sounds like a pretty easy fix, never removed that piece of trim before but I may just try that, because mine leaks too and it is quite annoying.
BigKO
326
Riverside
bioskyline;1662839 said:
i use Sikaflex-291 in black. works great.
Are you guys referring to the glue/sealant you guys use for the trim? Or to what you would use in order to seal the bolts holding the bottom piece of trim on ?
bioskyline
1,236
powell river bc
Sikaflex®-291 is a one-component, low viscous, medium modulus, polyurethane-based sealing/adhesive compound.
sold in boat stores, so i know its waterproof :D
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
I just siliconed those holes the other day, Grim.. I could never figure out how my hatch rusted out the way it did on the sides (by the tails), yet the rest of the hatch seemed fine. I'm pretty sure it was the same issue you had as well.
radiod
1,342
Abbotsford, BC
I know what I'm doing when I get a dry day or two now! I knew it was under that trim piece somewhere from pouring water on various locations of the hatch and watching for it, but didn't get a chance to pull it off before weather got ugly. Right now I have that panel just sitting in my trunk as a drip catch rather than pooling the water in with the rear wiper motor etc.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
Zumtizzle;1662921 said:
We knew about this in 2003 on Supraforums. ;)
found this out in in 2001 from when i was sick of my subs filling wiht water then i opened the hatch
then a glass guy i knew told me to cheak the black glass spacer
te72
Classifieds Moderator
6,611
7
WHYoming
I did this to mine, but she still leaks. Never did replace the hatch seal though, I'll probably do that on my new shell.
