ON GOING PROBLEM:
simply put.. the car over heats.
Now the fun part ::long breath:: car drives, boosts, starts, stops, FINE. The Napa leak down test (blow air through blue liquid watching to turn yellow) comes back NEGATIVE, (does not DIRECTLY indicate a BHG) While cruising, ~65MPH down highway (hot or cold mornings) it will heat up to right below red on a 15 min drive to work (starting from overnight cold) however if I put the engine between 1500-2000 RPMS the temp will NOTICABLY fall to operating temps. below 1500 will climb.. above 2000 will climb. however the temp does flicker while cruising. It over heats enough where I have to put ~1 gal of water in it everyday. The clutch fan does not seem to be malfunctioning but I am pretty unclear on the hot/cold test, and it doesn't fail the test thats in the TSRM. when I come home and its HOT.. air/vapor is comming out the Rad cap. and air/vapor/water is comming out the overflow. This issue has really been giving me pause for thought. I will be replacing the HG tomorrow but i'd like some FIRM, SOUND input before I dive in, in the off chance that it could be something else (probably by now my HG is getting ready to go anyway)
Aftermarket/performance parts:
HUGE front mount intercooler, w/ 2.5" piping from turbo to TB (could possibly be reducing airflow to radiator)
3" exhaust, turbo back
550 CC injectors
lex AFM, (electronics not hooked up)
MAFT Pro
Megan racing AFPR
Profec B Spec II boost controller (daily run 9-10 psi, highboost is ~14 psi)
HKS SSQV
thats all i can think of thats relevant.
Please any input is appreciated before I dive into the HG swap tomorrow. I'll be monitoring this most the night so please expect timely replies. JJ i'd love a comment from you.
550 CC injectors
MAFT Pro
Megan racing AFPR
HKS SSQV
