kyb gr-2 or tokico hp
which struts
  • Kyb Gr-2
    Votes: 15 50.0%
  • Tokico hp (blues)
    Votes: 15 50.0%
  • Total voters
    30
Grimsta
1,081
Santa Rosa, Ca.
TuRbOdReAmZ87;1179067 said:
Rick, my buddy has coilovers in his 91'. And my other friend has them in his 240. And from what they both tell me, its not that good to have them when its a daily driver. I would suggest not getting coilovers if your gunna daily drive it. But its up to you. I just sent you a pm btw.
Eh, its all a matter of preference. I DD'ed my Supra with the Megans for awhile, i liked it
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
The Megan coilovers are fine for DD. Thats the beauty of a fully adjustable suspension; you can track it one day, and DD it the next. Thanks again for the hookup.
kotu100
1,899
Easton, Ma
well i ended up gettin the kyb's from ebay. and i got one of them mini mkiii r/c cars lol.
we'll see how i like em when they come in.
ft413
learner
Sep 23, 2008
90
EL
i have the eibach lowering kit and the kybs and i like it a lot. its a pretty hard ride though but ull get use to it in about a day. turning is very easy at higher speeds too. car looks great after also
Koenigturbo
1,336
Oxnard CA
Poodles;1178923 said:
Personally I'll be going with bilstein's and stock springs since you can lower the spring perch on the bilstein's...
KYB's are a bit stiffer than stock as well.
Whats the range on the perche's??? Inch?? two inches?? Or did I missunderstood the idea.
5
Has 3 places for the snap rings that hold the perch, top is stock and the other ones are lower.
I don't recall how much they lower the car, but you can also get the coilover sleeves (no, not the cheap ones) for the bilsteins so they're adjustable to where you want it and you can use generic springs (all this info is in the suspension part of the forums)
becauseican
Vancouver
www.bicperformance.com
I have had the KYB's on my car and I hated them, they were as soft as the stock shocks. I now run JDM Bilstiens (JZA70 turboR) and I love them!!!, they ride great and are stiffer than stock but not rough. I also have Bilstiens on my 4Runner and they are awsome. I prersonally wont put anything else on my cars, unless I stepped up to coil overs. Infact many coil overs use Bilstien inserts anyways. The aftermarket Billies are adjustatble, so you can adjust your ride height too.....my $.02
