technically, it's
Zenki (86.5-88)
chuki (89/90)
kouki (91-92)
but we don't use 240 language here..
anyway, don't do it, especially to a 91...
you might as well swap moldings and taillights, mirrors, and sawblades on it while you're at it..
lewis15498;1532115 said:
I would not, I think the 89+ looks much better. But thats an opinion and yours matters not mine. You will need to change directionals if you change bumpers tho.
you don't
need to if you're going from pre 89 to 89+, but for the other way around, you can either swap in a pre 89 header panel and use the older signal/grille set-up, or you can do what A-to-the-J did, and use 2 pre 89 grilles cut and mended..
