knock sensors and what do they do
viper92086
932
NJ
Hey all, i've been trying to read up on what a knock sensor does for our car but pretty much of the threads i found were of code 52 or the wire breaking... what exactly does a knock sensor do besides detect knocks. Does the ecu use the vibrations to calculate any sort of data? i know i read that someone said when it detects a 7hz knock, thats when we get the code. But what i don't understand is how can the engine even run right if someone did the bypass mod. So say the ecu wasn't getting the knocksensor signal correctly, is it possible for the car not to run at its optimum, without even throwing a code?
Jeff Lange
Administrator
4,919
Sunnyvale, CA
jefflange.ca
Knock sensor is there to protect the engine from knocking (pinging). If your engine is running and there is no knock, there is no need for it. It's a safety measure.
viper92086
932
NJ
o ok, so it has absolutely nothing to do with performance of your motor, it only serves as saftey if something were to fail
viper92086
932
NJ
alright i was j/w, i'm doing the rewire tonight and was thinkin maybe the knock sensor had sumthing to do other than saftey
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
when you are pinging, the engine retards timing. It is to minimize detonation thus protecting the engine internally.
viper92086
932
NJ
basically i wanan know is if the knock sensor is contstantly telling the ecu to adjust the timing, would have one with a loose connection reduce performance, meanwhile WITHOUT throwing a code?
The knock sensor does "listen" for a 7 kHz frequency...this is the frequency that is produced when the engine experiences knock. However, this is not what produces a code 52. This code indicates a problem with the knock sensor circuit (open or short), the knock sensor itself, or the ECU.
When the ECU gets the signal that knock is occurring in one or more cylinders, it will retard timing. It bases the amount of retard on if the knock signal is "strong", "weak", or in between...basically it steps the amount of retard. When the knocking stops, the ECU restores timing advance a little at a time in fixed degrees.
When you have a code 52, the fail-safe function of the ECU sets ignition timing at a fixed retard angle (no more than 10 degrees iirc). This will definitely affect engine performance.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
When the ECU gets the signal that knock is occurring in one or more cylinders, it will retard timing, but no more than 10 degrees. It bases the amount of retard based on if the knock signal is "strong", "weak", or in between...basically it steps the amount of retard. When the knocking stops, the ECU restores timing advance a little at a time in fixed degrees.
When you have a code 52, the fail-safe function of the ECU sets ignition timing at a fixed retard angle. This will definitely affect engine performance.
The explanation doesn't get any better than that viper.
jetjock
creepy-ass cracka
9,439
Without going into detail the knock system is not passive but neither is it full time. The parameters needed to turn the system "on" are the same ones used to set the code ie; when the parameters are met the ECU begins knock control. If at that time it doesn't see the signal(s) used to monitor the sensor(s) and wiring it will set the code. Such use of shared programming for both control and diags is common in the TCCS.
Many knock sensors use an integral resistor to ground so the ECU can tricle some current through it to verify wiring. If you ohm a 7M sensor what do you get? Based on that one should ask oneself how the 7M ECU knows when the wiring is bad. The answer isn't hard to figure out if you think about it.
viper92086
932
NJ
i kinda understand how it works.. i was just wondering maybe my knocksensor wire could lead to my car not pulling as it should on some days... But keep in mind the light never came on until now.. so it was just a thought. Thanks guys, like i said i have the wire in front of me right now as i type this at work and i got the sogi how to so i'm set. i am going to be using the same sheilded thinnet wire as in the guide.
viper92086
932
NJ
just out of curiosity is there any long term effects of code 52? since i am driving to canada in 1 week to road race i want to be able to make it back just in case this code haunts me... (NO i will NOT race if i am pulling code 52) thanks again
figgie
Twin Cities, Minnesot-ah
ATL88Supra said:
i would never run a turbo charged eng with out knock sensors
<-- runs a turbo charged engine without one single knock sensor ;)
But I am standalone and so are the three other folks that I know that do not run a knock sensor.
