Is that's why my speedometer doesn't work due to a bad knock sensor. So once the knock sensor is fixed, that the speedometer will work again? That would be great.
supra_89_vang;1102414 said:Is that's why my speedometer doesn't work due to a bad knock sensor. So once the knock sensor is fixed, that the speedometer will work again? That would be great.
supra_89_vang;1102889 said:My fault, I miss read the post before about the speedometer.
castrol supra;1043996 said:They are right around $350.00 at the dealership.
Owner raping bas-tards.
The stealership. Not you guys.
does anybody know where in the t.s.r.m they talk about the knock sensor and location?Poodles;1102933 said:Find a new dealer, they're $150 from Champion...
I can feel my knock sensor, i think it's on the left side,can i just pull it out because i fear that it will fall down to the oil pan or jam something up.Whats the easiest way to get that dam sensor out?shaeff;1102970 said:I'm having difficulty accessing the TSRM online, too.
That being said, I don't think you can test the KS's unless you have an o-scope.
It's on the drivers side under the intake manifold. They screw in, if I remember right they have a release on the connector you have to push on to release the wire.supraman508;1104948 said:I can feel my knock sensor, i think it's on the left side,can i just pull it out because i fear that it will fall down to the oil pan or jam something up.Whats the easiest way to get that dam sensor out?
CRE;1112734 said:The spark is still controlled via the ECU. The means of delivery is the difference. The ECU reads the cam position (and several other things) decides what advance should be run and then signals the igniter sooner.
