Knock sensor thread size????
yankiwi
221
DFW
Just like the title asks, I am drilling/tapping a second KS on an NA block that will have turbo electronics running it. I don't have any access right now to measure one and need to buy the correct drill bit and tap.....
Anybody happen to know the size? IJ you know this right!
MDCmotorsports
Indy 500
www.MDCmotorsports.com
The thread on the knock sensor itself might be a taper design, but as stated above the thread should be the 12mm.
Also, get yourself a bottoming tap and use plenty of cutting fluid. Cast iron is NASTY stuff. Go slow and don't break it off.
yankiwi
221
DFW
Thanks guys, I knew it would be the size that I don't have yet... off to the hardware store then for a 12x 1.25 tap......
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
its a good tap to have as its the same as the headbolt holes in the block so by having that you can chase those out anytime the head is off.
