nah, something is amiss, here. grab your multimeter, set it to continuity check, (usually has a beeping sound when you touch the probes together)
now, touch one probe to your ground, and the other to the signal wire. any continuity?
double check that you have continuity between your ECU connection, and the KS connection. a new KS connector wouldn't hurt, either. P/N: 82219-89103
i wouldn't EVER re-use an old connector like that, especially if a new one is so cheap!
also, when i made a knock sensor rewire harness for s383mmber1's car here on the forums, i did it differently than you did. he's also got an N/A->T using GTE electronics.
i made the pigtail on the KS harness, meaning that instead of soldering the two KS inputs together, i simply made a U shaped piece of wire going from one signal wire to the other. it works flawlessly.
Knock sensors don't normally fail, and it's rare that you'll get two that are toasted one right after the other. i'm betting that your wiring isn't up to snuff quite yet. stop throwing parts at the car and diagnose it.
