knock, knock, knocking on...
rakkasan
Currahee!!
Fort Campbell, KY
SublimeSupra said:
A tight ac belt combine with a loose crank pulley is what i meant to say IJ.
exactly. Fatality is saying that the knocking condition only occurs when the A/C is on. My thoughts are that the the harmonic balancer was damaged from being driven while loose. That's a given. Now after fatality tightens it, he can tighten it just enough to end the chatter. But when the A/C kicks in, the additional load from turning the A/C compressor & a belt that is too tight *might* cause enough undue strain on the drive belt & all pulley's attached to it to loosen the Harmonic Balancer (or even round it out some more).
jdub
Feb 10, 2006
10,730
Valley of the Sun
:withstupi
Well said ;)
