knock, knock, knocking on...
fatality
I was speeding?!? NO WAY!
Mar 1, 2006
51
Houston
Hey guys,
so there is this knocking coming from the nose area of my friend's 7MGTE. he pulled it hard in fourth all the way up to 6k rpm, then again in fifth to about 5500 rpm. the retard left the AC on full blast. he pulled over and noticed the main crank pulley was wobbling. upon getting it home very gently, and letting it cool down, he noticed the main bolt was plain loose (he hand tightened it about three turns). So he tightens is up completely, the knocking goes away for a couple of days. 3rd day, he ran the AC again, the knocking came back, even though car wasn't driven hard (no boosting). the pulley was wobbling again as well. he let it cool down and the bolt was still tight. any ideas?
fatality
Mar 1, 2006
51
Houston
IJ. said:
Shagged the inside of the Balancer and possibly the Key/Keyway and Crank snout!
what shagged? more explanation please.
also the wobbling goes away with the knocking.
If it's been run with a loose bolt it wears the inside of the balancer and in bad cases all of the other components I listed can be damaged as well.
"Tight" in this case is 197 ft/lbs
miggles
i wasnt speeding officer
Jun 3, 2005
526
perth West Australia
when you say wobbling is it moving forwards and backwards? like to the front of the car and to the back? If so then it could be your thrustwashers worn out but it would seem like what was mentioned above.
fatality
Mar 1, 2006
51
Houston
no it wobbles from driver's side to passenger, but only if the AC is turned on. otherwise the car runs normally.
fatality
Mar 1, 2006
51
Houston
Boss302 said:
so it's only wobbling while the A/C is on?
yeah only when the AC is turned on, and then it wobbles and a knocking sound shows up. after shutting it down have to tighten the bolt to specs again and it runs perfectly. You think I just need to replace the compressor?
jdub
Feb 10, 2006
10,730
Valley of the Sun
Dude...re-read what IJ and Rakkasan posted above...now focus and understand: YOUR CRANK PULLEY (harmonic dampener) IS DAMAGED...PRAY YOUR CRANKSHAFT/KEYWAY ISN'T DAMAGED TOO
:slap:
rakkasan
Currahee!!
Fort Campbell, KY
How tight is your AC belt? Is it so tight you can play it like a banjo?
rakkasan
Currahee!!
Fort Campbell, KY
Boss302 said:
When you have the A/C belt too tight, it causes the rear passenger tire to lose its' balance & the vibration transfers through the unibody to the motor causing the harmonic balancer to come loose. :icon_conf
Bad man Mark baaaaad man ;)
(LMAO here)
SublimeSupra
Dreams of the Touge
Jan 17, 2006
170
Largo,Fl
Well what everyone is saying is generally the same.Probably your ac belt is on super tight,and when you turn on your ac the compressor puts even more parasitic drag/stress on the dampener/pulley and then causes the crank pulley to "walk."If you drove around like this for awhile it will eat the key on the outside of the crank/inside of the pulley/dampener.If it gets to bad then you have to find a new crank or get a new dampener/pulley and get the snout of the crank wielded with a new key which i dont recommend.
Sorry but I don't think anyone is saying a tight AirCon belt is the cause here.
NOT doing it up to 197 Ft/Lbs is the cause the effect is at best a damaged Dampener but by this time if he's kept driving it the Crank and Key are probably toast.....
