Well, I just killed 3/4 gear in my R154.... this is the 4th trans. My car does make over 500 flywheel hp.
I have not had a thrust washer failure yet. I lost second gear in one trans, one I broke a shift fork in, and I've had two loose third and 4th gear.
You can click the shifter into one of those two gears, but its not there. no noise, no nothing.
Story behind it breaking:
One day, it got hard to shift for no reason. I wasn't romping on it or anything(but only 3/4 shift)
The next day, I accelerated in 4th gear a little... when it hit boost, it poped out of gear. When I tried to put it back in... no gear.
So I went to 5th. Normal. Tried third and it just poped back out. After that, no third either. All other gears work perfectly normal.
