keeping polished aluminium shiney
KMinAF
Old Man
Sep 15, 2006
291
American Fork, UT
I just finished polishing the valve covers and they look great! How do I keep them looking shiney? Should I apply a clear coat?
I know I have read about this before but I can't find anything via search.
shaeff
Kurt is FTMFW x2!!!!
11
Around
No clear coat, as the heat from the engine bay will make it yellow and crispy. Then you have nasty looking yellow cam covers.
Not sure how to keep them shiny, so that's all I've got for you. :)
selfinfliction
434
ky
you can use zoop, it'a about th eonly thing that will keep something from oxidizing, that gets hot.
on all the parts that don't get hot i use flitz, on hot parts zoop or clear coat, and not the aerosol canned clear, good stuff. zoop is expensive, that's why i only use it on hot parts.
here's a difference, the sprocket has zoop on it (cause they get hotter than hell) and the wheel has flitz. you can see a noticable difference in the shine
it is more noticable in person, the zoop has a brighter shine cause of the protectant layer on it, and flitz just leaves the deeper look, but only lasts 6 months compared to 2 years of zoop
metaphysico
Mad Scientist
Jan 2, 2008
428
Gainesville, Georgia
Mothers polish lasts for 3 months or so with no polishing in between, but if the car just sits it wont last as long. Blue magic lasts for 6 months + but it leaves a film in not rubbed in enough but will hold up pretty well.
Of the 2 I usualy use mothers every 2 months or so, light coat on and off no buffing required if done often enough. Its a little hard to get under the intake though.
There is also stuff called 200 mile per hour polish used for plane props, From a guy I know its the best stuff, heat tolerant, durable, and you just wipe it on and off like polish and lasts for over a year on a plane prop.
p5150
ASE and FAA A&P Certified
Central Idaho
I use Glisten PC by POR15. It is a catalyzed clear coat that wont yellow. It is specifically used for polished metal surfaces to include chrome.
mista_sup
211
atlanta
so what if you already used the reg. clear coat and it turned yellow. how do you get it off. and where can i get glisten pc?
selfinfliction
434
ky
p5150;983637 said:
To get off the old clear you could probably just use some automotive paint solvent or aircraft paint stripper.
I would avoid physical means like sandblasting because you will have to polish it again.
+1 aircraft stripper is my mistress.
it'll take off just about anything but powder coating
suprashy
126
Nassau County, NY
I had my valve covers and intake plenum polished. As long as she was garaged, all was well. But after storing her outside, now my parts have oxidized. :( I used mothers, and the 200 mph polish, but I guess mother nature is too strong. I'll have to try zoop.
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
Zoop is damn good!
I will be getting some of my parts clear anodized after polishing as well since the shop next to ours has a connection at an anodizing place!
Self hang in there almost done!
P.S. We need to talk about a deal for polishing!
HTH,
Seth
selfinfliction
434
ky
sethron71;984224 said:
Zoop is damn good!
HTH,
Seth
yeah man, i'm definitely up for it.
