Keeping everything chilly mac: Is this overkill?
Dizzy562
4
Long Beach, CA
I'm in the process of rebuilding my 7MGTE, and want to know if my cooling solution is a bit overkill. I'm in Southern California to give you all an idea of how high the temperatures are that I'm dealing with.
My plan is a DriftMotion IC kit, a new OEM fan clutch, brand new hoses all around, and hopefully a vented hood to get rid of excess heat from the top of the engine. The engine specs include a stock rebuild of the bottom end and head and a 57 trim CT26 at 14 p.s.i. (if this helps).
:1zhelp: This is my first turbo car, so any and all input will be greatly appreciated and considered.
bhmsupra
529
It's Not Important Bro
Ceramic coating on exhaust mani. Put a bag on the hot site of compressor wheel. I dont have any statisitcs to back it up, but just from my hand and touch, I can tell you it makes a world of difference.
bioskyline
1,236
powell river bc
could always do the multi electric fan mod lol
but a bigger rad will also help
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
a thermostat that opens at earlier temps i believe stock opt temp is 196F dont go below 180f and make sure all ur fans work !! i live on south florida so i new a few things of heat lol
IBoughtASupra
4,455
Queens, NY
Use a 80C thermostat as the lowest. Do not go lower than that. Make sure your fan clutch is good as well, if not, Google how to rebuild it, it is just really the changing of the fluid inside.
Vented hood isn't needed. I see no mention of a fan shroud, so I'll mention it (yes it's important). Also making sure all the plastic air guides up front are in place. When you remove the radiator and intercooler, clean the A/C condenser really well.
Skip the lower temp t-stat (it's pointless), and are you replacing the radiator?
Damn poodles double posted.
Ya use the factory 190* t stat. Get a nice big alum rad and your set.
Weird, I didn't hit post twice or get any lag... I blame IJ (it's always his fault)
Even a good factory replacement radiator would be fine. You're replacing everything else in the system, might as well replace the one thing that actually does the cooling...
Dizzy562
4
Long Beach, CA
Thank you for the input, more stuff to add to the list! I have no idea how I let the radiator and fan shroud skip my mind, so I'll definitely be picking new OEM units up. As far as the fans go, I know a lot of 240 guys run the bigger Taurus fans so I think I'll do that as well since it will be the most cost effective choice.
Stock mechanical fan works perfectly fine, no need to mess with it. Shroud is a dealer only item (if you have one that's in good shape, no reason to replace). As for the radiator, there are upgraded units that cost a bit more than an OEM units, just shop around ;)
It is true it's my fault! ;)
Devin LeBlanc
1,830
Las Vegas NV.
Im running a Taurus fan and its amazing! However I upgraded my alternator to a high amperage one to cope with the extra draw, Best thing I have ever done to my cooling system! I had a shrouded clutch fan with new radiator and was slightly overheating in the summer time (117F with the A/C on) At long stop lights I would boil coolant out..
With the Taurus fan on high it pulls about 48 Amps so a bigger alternator is needed! Do the wiring right it helps a lot with properly setup relays and such!
The Taurus fan is a perfect fit, with less than 1/4 inch away from the water pump pulley.. Make sure your motor mounts are good ;)
IBoughtASupra
4,455
Queens, NY
A properly working fan clutch with the GTE blade, a fan shroud and an aluminum radiator will last you in those 117F with the A/C on. Clutch fan wins any and everyday.
Crypton2006
294
Phoenix Az
I have a good working stock fan, koyo radiator and ceramic coated turbo and down pipe. I did about 20 dyno pulls making almost 500whp in phoenix when it was 115 outside and about 120 inside the shop. and never went over 200 degrees. although my bumper did catch fire due to lack of air flow..lol
