(It is kind of long, but please read it through and see if you can help me with bits and pieces and maybe if someone doesn't know it all it can be pieced together. Thanks!)
Ok, I've attached pictures and the four files/diagrams I'm working with so this can be clear.
I've wired everything from the EA2 diagram except for connector F, for hydrofan as I'm not using it. So that is checked off of the list, for now. I see another thread about using some of the EA2 wires for A/C, didn't do that.
I've wired everything on IH1, except for the "IG2" wire. There is no wire for it coming from the jza70 harness and no wire to wire onto on the B1 connector. So for now, it just isn't done.
I started wiring up IH2 (Please refer to the diagram to make things clear), the white connector from the jza70 harness. Again, I'm having an issue or two with some wires. :sarcasm:
I've looked over the list and figure out I don't need to hook anything up frmo the white IH2 connector except Pin 5 "Cruise ECU Pin 9" (O-Optional), Pin 18 "II1 #13 A/C amp", and Pin 19 "HL relay". Everything else has to do with Auto tranny, SRS, TEMS, ABS, and hydro fan, none of which I have.
You're probably wondering, only three wires from this harness this guy has to splice and he has trouble already :icon_razz (Pin 5, 18, 19). Well keep laughing, I looked at the white connector and there is no wire there for pin 5, so I didn't connect anything. I guess this means Cruise won't work? (Actual question).
Pin 18 for the A/C is supposed to go to B1-13. I notice that from the IH1 diagram (please look at it to follow along) that B1-13 is already taken, with another A/C wire, so I spliced both into the B1-13, is this correct?
Pin 19 for the HL relay. Those are the first two pictures below.
From the diagram, it says I should be taking a red/green wire from pin 19 off the jza70 white connector (IH2) and splicing it into a red/green wire on the USDM B1 connector, pin 22.
Both ends of this are confusing for me as you can see. Coming off of the jza70 harness, I notices it was red/yellow. The way things were going so far, I said ok, close enough, it's the right pin. Then I got to the B1 connector, and it's a BROWN wire. Even so, I was ready to go through with it, but I saw right next to it, in pin 21 there is a red/green wire. Coincidence? Who knows. Seriously, who knows? I don't. Should I splice the two wrong colour, mismatched wires together because they are the right pin, or is something wrong? Ok, that's it for my woes, some trouble with IH2.
The other pics now, the following pics should be simple and quick. As you can see, the first plug is off of the harness and I'm not sure where it's supposed to go, my question: where does it go? I ask because I'm not sure if that plug will work or if I have to get one and splice it on there.
The second pic is another set of wires further down the harness, near the intake manifold near the back of the manifold/engine. It has no plug on it so I'm wondering where this is supposed to be going, to the starter?
The third pic shows those wires up close, one is brown, one is light green, and one is blue with a black stripe.
Fourth pic is a cluster of plugs, what do these go to, are they all compatible with the plugs in my car or do I need to splice other connectors on there? I'm asking about them because I was told I wasn't given all the connectors I need the those four diagrams don't cover everything.
Lastly, in that cluster of foru connectors from pic 4, you will see the one to the far left is just two wires, no plug on it. I'm wondering what this goes to and what kind of plug I'm going to need. If I can't get the plug I can look at what it goes to and cut off the other end plug and use a matching set.
I didn't take a pic of it, but near EA2 there is a large connector and a smaller 4pin connector, what are these for, last question
