i have a jza70 supra that i finally got running better after sorting out major vacuum problems but found it was still throwing a check engine light. i checked the code and got a code 52 for knock sensor circuit. should i check for continuity to the pins at the ecu? the wiring on the car is kind of a mess from the previous owner so could it be worth just rewiring the knock sensors? ( i understand there are 2?) what would be involved with this?
