so ya after i get my tts and tps this wk. i will adjust the timing. and hopefully shell be fine after that. i know both these sensors are makin her run like doo doo.
i was lookin and code 51 is also for a/c, i dont have any a/c components, connectors hooked up. this could be the reason for code 51? if so maybe my tps is fine. what do ya think?supramike7m said:what code would a tts throw? also what is the switch on the bottom of the housing?
jetjock said:Mike, there are lots of posts that cover this (one of which I just posted today) but no, if you don't have AC it won't be the cause of code 51.
It's easy to check your TPS and CTS, either on the car or off. Search todays posts for advice or read the manual. No manual? For shame. Look at the one online and after go buy one. It'll answer everything you asked and more.
Prescott: great place btw....
jetjock said:If you don't own a manual and intend to keep the car go out and buy one, a real Toyota one.
