I used the plastic paint and vinyl dye for all the right areas and never had an issue... even the kickpanels did good.
I did load some stuff in the hatch and put a good scratch in the panels tho.  Still, if you're careful and don't "purposely" dig into it with a sharp object, it should last awhile.
I got lots of props on mine at 2X2K5 and had not even touched it up (over a year with the original dye/paint).
The only thing I'd add, or do differently, is use different material on the headliner and panels/inserts.  I used a black crushed-velvet deal and it looked great.  Unfortunately, I only have black/white pics of the whole thing in black, 'cause our old camera sucked.  The black carpet also set it off.
Here's how I re-did the door panels on my 87T (eventually dyed black), but this shows how I replaced the carpet on the bottom and the material for the insert.  I also recovered the speeaker grills in black (using speaker fabric).
