Just got a bhg. Stock engine wit felpro and arp's. Only took 20psi on my MP t64 to do it lol. The good part is during the 3rd gear pull that blew it my a/f was sitting at 11.2 the whole time, finally got the maft pro tuned right.
IJ.;1539451 said:More than likely the effects from "incipient detonation", you don't hear it but it's there rattling away in the background.
You can have perfect AFR but if there is too much timing/boost for the octane fuel being used it WILL detonate Alec.Alec;1539457 said:Not to sound like a noob here, but if your A/F ratios are good, why would there be detonation?
IJ.;1539459 said:You can have perfect AFR but if there is too much timing/boost for the octane fuel being used it WILL detonate Alec.
IJ.;1539461 said:There are a lot of variables but yep that's near enough, anything you can do to lower the intake charge temp helps keep it out of det but there are hard limits involved, you can pull timing but you get to a point where you would be better off dropping boost and adding timing as it makes the car nicer to drive.
Alec;1539464 said:You just got me slightly worried earlier which was why I asked. My friend has a MKIV with a 6262(.58 AR) turbo on stock 550's(cleaned and flow tested) with a Bosch 044 pump and raised fuel pressure. Stock ecu, just a VPC/AFC. He's got it tuned for 18 psi on 93.
IJ.;1539512 said:I tend to be very conservative when I tune and always have a good safety margin in my engines to allow for a dud load of fuel if I'm 1000Km from home.
I also monitor EVERYTHING and on the new engine with be using active knock sensing/control for the first time.
Never been a big fan of Piggyback controllers due to the way they need to fool the stock ECU into doing something it wouldn’t normally, much prefer to set xx degrees of timing and it means just that!
