Viper, try lowering the fuel pressure and upping the WOT (airflow signal).
This definately takes balance, you're not only trying to keep your AFR's straight, but also avoid fuel fut. The more fuel you add via airflow signal, the closer you get to fuel cut.
The theory behind this is, the more you pull fuel via airflow signal, the more your timing is advanced. This is because supposedly in the ECU your timing is determined by the airflow signal VS RPM, etc. So less airflow = more timing because the ECU believes there is less boost. Get it?
