Just bought a supra need help
terror
Antibliss
Jun 13, 2008
242
Alaska
Just bought a 89 1jz 5speed targa hks sport turbo supra and the drivers window doesnt roll up, looks like it fell off the track and the motor is shot, is there anyway to manually get the window to go up and does anyone have a window motor for sale. thanks
My passenger window died once (happens a lot with MKIIIs) and I could not for the life of me force it up or down. I've got a spare passenger regulator and motor though, and I'm pretty sure the motor is the same for both sides, just flipped if you need it.
Try putting it back on the track first, just in case the motor is ok =]
Vector89T
stickerdave.com
Aug 21, 2005
51
Lafayette, LA
If it's off the track, you could damage the window if you're attempting to "force" it up. Try to get an eye on what's going on in there and see if everything is in place in the track. If it's not, get it in the track first.
Another thing to check, the windows switches in the MKIII are infamous (at least down here they are!) for corroding on the inside and the switch will not operate the motor. When you say the motor is shot, is it not doing ANYTHING or does it attempt to run the motor and it's just weak or malfunctioning?
If it's possibly just a switch issue you can roll the window up with a 12V battery source (car battery, jump box, whatever) with just a couple wires in the window regulator connector. The polarity will not harm anything, because that's how it rolls up and down. Wired one way, it goes up, reverse polarity it goes down. :)
Do not attempt to force the window by hand or with the motor if it is not on the track. Also do not attempt using a jumper wire to jog the window up or down if you're not familiar with doing that sort of thing. I can explain more in depth if it comes to it.
terror
Antibliss
Jun 13, 2008
242
Alaska
well its definatly off the track and ima try to get it on but i tested the switch, its fine but when i press it down i can barely hear the buzz of the motor attempting to spin but no movement at all, btw i also need a new windshield lemme know have one, thanks
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
when my drivers side motor went, the window seemed to be off the track, but it wasnt.
i pulled the door panel off and unbolted the window from he motors arm. I was fortunte enough to have a friend on hand to hold the window up while i pulled the motor out, and put the new one in place. But i guess mine was stuck closed, and i didnt try to hard to change its direction.
terror
Antibliss
Jun 13, 2008
242
Alaska
bought it off someone on these forums, thanks for the info
Basically I'd redo as many hoses, gaskets and vacuum lines as possible. I'd change all of the fluids, so you know what you've got in there. Anything made by RedLine should be good to go. http://store.summitracing.com/egnsearch.asp?N=400236
This link here may help you as well. http://www.supramania.com/forums/showthread.php?t=16&highlight=upgrade
Just about anything you could ever want to know is already here if you'll just spend a few minutes with the search function. If you can't find what you're looking for then ask somebody. As long as you've tried to find the answer yourself, you'll get some help. Good luck.
terror
Antibliss
Jun 13, 2008
242
Alaska
thanks alot man
