Hi Ron,
Just moved over here from Supraforums (where I haven't posted for a few years). I love the work you've done, thanks for taking the time to document it and answer questions etc.
I'd like to know a little more about the process of converting to dry sump. Does the pump just suck from the sump, or is there a line from the pump to the turbo oil drain, some points in the block etc? Where does the pump connect to the engine block in order to feed the pressurised oil back in? Do you have to balance the suck and blow side of the pump in some way to get the oil pressre right, or do you just buy a pump and strap it on? Finally, why did you decide that the stock 2JZ oiling system was not up to the job?
I can't see many people going this route due to the high cost, I certainly couldn't justify it, but I'm sure I'm not the only one that is interested to know the details of how it's done.
Anyway, have fun breaking it in, and be sure to post plenty of vids when you start whaling on it! :naughty:
Adam
Adam
