Alright, helping 7MBoost out and here's what I need to know
1) The AEM uses ONLY the 'Engine Start' tables to get the car cranked, then switches to the 'Idle' tables, correct?
2) Does the 10-1130 AEM need to have the fuel resistor pack, or does it need to run the injectors directly?
3) Set of Delphi low imp 750cc injectors - which of the maps for the battery vs pw is going to be closest?
That should get most of the information I need. The manual is fairly unhelpful thus far
I can get the car fired up in Alpha-N mode, but I really want to get the speed density working
Going to work with the setup some more tonight, and hit the car again tomorrow!
