JIS 7M Rebuild Kit
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
Moy;1281096 said:
probably garbage. its 248... for about 100 more you can get a full gasket set from toyota
did you look at what the kit includes? It is a bit more than just gaskets...
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
oops, didn't see that. also pistons, wrist pins, bearings, timing belt, and oil pump?
definitely seems sketchy then, 250 for all of that... that's too cheap... I personally wouldn't trust it, but that's me
dopeassjackson
64
ny
i bought basicly the same off brand rebuild kit for my nissan 240sx motor. i had to replace the timing chain guides and head gasket. other than that the engine has lasted some abuse. i turboed it with 10psi about 25K ago.
if i where to buy that kit i would chuck the timing components, headgasket and oil pump.
