Anyone running JIC upper camber arms and coilovers on their A70 or Z20? I've just been reassembling my front end and it looks like the JIC arms foul on the bottom of my tien coilovers. I don't think the base is much lower or wider then standard springs and shocks, so am I missing something?
They are marked L and R, both slightly different offset of the balljoint, tried both on the same side and they still seam to foul.
SO guru's am I missing something or do JIC upper camber arms and Tien coilovers not mix? If not, what coil overs are you successfully running with your JIC upper camber arms?
Pics:
L on the passengers side (correct way round).
Showing the offset differences of the balljoints.
R on the Passengers side
Cheers
Leigh
Pics:
Cheers
Leigh
