Jetta lowering springs on my supra?
Status
Not open for further replies.
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Yeah, considering they're a freakin' four door family car I'm glad they do, even if it is only by 9.6 lbs.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
theWeezL;1033057 said:
well...a spring is a spring is a spring, BUT, they have different heights, bar thicknesses, and diameters not to mention they still have to seat in the mounts properly (ie. some springs have a few tighter radius coils on the end to fit the mounts). If you have a spare supra spring hand you can compare it visually at least. Im guessing its not even close.
Springs also have a stroke before coilbind and many different winding options, from progressive to pure linear.
In order for these to work at all, the car would need to be about the same mass, weight distribution, same suspension type and leverage ratio, same perch dimensions... then it would only be a crapshoot.
You can do the research to find out if you have a snowball's chance in hell if you like - I'd advise doing it before trying to mount anything, that's for damn sure.
Otherwise, sell 'em and use the money to pick up a set of used springs that someone else has already put all the engineering time into.
giterboosted
cure for the common rice
Nov 3, 2007
597
toccoa ga
ok i may have missed something here, but for the record the supra weighs 4460lbs, so says the tag inside my door jamb telling you the weight distribution, so unless you mean at each corner, you are all gravely mistaken on the weight
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
giterboosted;1033608 said:
ok i may have not researched this enough but...,
:naughty:
Lawl.
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
Damn it ........ public school systems
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
adampecush;1033615 said:
look up the meaning of gvwr, and then feel shame.
I was gonna say something myself, but you got the point across better than I could have, lol.
Grim, I knew there was more to a spring (admittedly more than I knew) but I was figuring it woudl fail the visual inspection for dimentional reasons long before the rest of the factors needed to be taken into consideration.
Selling the springs to someone who can use them and getting what you need is the best idea.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Ya, I figured you did - I was trying to post additional information instead of contradicting. Sorry if I came off as a bit of a dink! :)
RyDeFly
Westminster, CO
I can believe that the jetta weighs 1370 kilograms, but a turbo supra weighs 1570kg (according to toyota's commonly printed specs at least.)
Status
