i have never really heard of anyone running an aviation grade oil in there car. i work with it all the time in my job and have access to it. pretty amazing how well the stuff holds up to the heat and wear. would it be worth a try? or just stick to normal synthetic? this is what i got from it...
MIL-PRF-23699
Type II Synthetic
viscosity of 5 centistokes at 100 Deg. C
made with neopentyl polyol ester base stocks
Typical Properties
Viscosity
cSt @ 40ºC (102 ºF) 26.4
cSt @ 100ºC (212 ºF) 5.3
cSt @ -40 C (-40 ºF) 11,500
% change @ -40 C after 72 hours -2.2
Pour Point, ºC (ºF), ASTM D 97 -62 (-80)
Flash Point, ºC (ºF), ASTM D 92 254 (489)
Fire Point, ºC (ºF) 288 (550)
Autogenous Ignition Temp, ºC (ºF) 399 (750)
TAN (mg KOH/g sample) 0.08
Specific Gravity 1.0044
Evaporation Loss,
% 6.5 hr @ 204 ºC, 29.5"Hg 2.1,
6.5 hr @ 232 ºC, 29.5" Hg 7.4,
Foam, ml
Sequence I, 24 ºC 0
Sequence II, 93.5 ºC 10
Sequence III, 75 ºC (after 200 F test) 0
Foam Stability, after 1 min settling, ml 0
Rubber Swell
F Rubber, 72 hr @ 204 ºC, % 20.8
H Rubber, 72 hr @ 70 ºC, % 20.0
Sonic Shear Stability,
KV @ 40 C, change, % 0.7
Ryder Gear,
average lb/in % Hercolube A 2,715 ,114
MIL-PRF-23699
Type II Synthetic
Typical Properties
Viscosity
Evaporation Loss,
Foam, ml
Sequence I, 24 ºC 0
Rubber Swell
Ryder Gear,
