ok so i measured my gap of my piston JE chromoly piston rings a couple days ago. Now i read what they are supposed to be on JE's website and IJ's recomodation of how to gap it.
So the motor i have was just recently built (dude said about 10k on it, but it looks brand new inside, still see cross hatching on evrythin in there) and im redoing it on a count of a spun bearing as most of you prolly know from my other posts. :aigo:
Its a fully built motor, and bored .20 over. The top rings all measure good being around .017. But all my bottom rings are all around .030ish... :yikes: from the math of how many thousandths to add per in of bore, it says to be around .018 and with IJ's input of adding another .005 to the gap for higher horsepower it should be around .023 of a gap.
So im talking to this guy at my work that builds bikes n cars, and he said it shouldnt be a big deal.... ya theres gunna be a very little loss of power, but nothing that should matter. He said better bigger than smaller, especially if its gunna be a high HP motor.
So i want to know what you guys think about my 2nd ring being a little bigger than the recomended gap size.
i had the car running before and it had great vacuum, and pulled strong! never checked compression, but it felt good. lol
Im gunna check it again, and by the way, i put the rings in by pushing it down with the piston to try and keep it level.
thanks and let me know what you guys think.
A new set of rings are $160 and i dont really wanna buy a new set if theyre not needed.
