Is there an differences between a JDM and USDM head? Could I bolt a JDM head right to a USDM block?
IJ.;1301055 said:Practice safe head jobs![]()
92TealSupra;1301099 said:From what I understand, the o2 sensor is different on JDM Supra's. It senses different hydrocarbons and chemicals in the exhaust to the ( JDM EECU )..
92TealSupra said:Well depends? Do you have a JDM ecu? Do you have a Egr and egr cooler?
From what I understand, the o2 sensor is different on JDM Supra's. It senses different hydrocarbons and chemicals in the exhaust to the ( JDM EECU ). This is because it has no EGR. if you have a USDM ECU you need a EGR and EGR cooler, and you can place the head on a USDM block.
adampecush;1301115 said:I didn't realize oxygen in Japan was different from the rest of the world.
(oxygen sensor senses OXYGEN, nothing else...why would it be different?)
