JDM throttle body?
jdub
Feb 10, 2006
10,730
Valley of the Sun
jdub;952573 said:
What you're referring to is the vac source for the EGR VSV on top of the TB...USDM has 2 there, JDM has 1 (for the BOV). T If you have removed the EGR, the one for the BOV is all you need.
MK3Brent;953376 said:
JDM 7M-GTE's use that port for the bypass valve?
Really?
You got me again Brent...it's for the charcoal canister BVSV. I knew that, but typed BOV instead :3d_frown:
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
Thanks for all the help, guys! :)
Now it looks like I just need a bracket for the kick down cable, instead of a complete TB.
jdub;953384 said:
Where did you get that motor and how do you know it's JDM?
Just so you know, it's a crap shoot installing a used engine...especially one you don't know the history on.
First off, the engine is a USDM and not a JDM. The previous owner blocked off the EGR ports, so with the EGR blocked off; I figured that I could run either a USDM or a JDM TB will little hassle.
The engine was purchased from another member on here, and from what I was told of the engine; It sounds like there should be a lot of life left on this engine. I know that the lower end has been gone through, as there's a remanufactured plate stamped into the block; and some heat tabs stuck onto some of the freeze plugs.
