hey guys i did some searchin to find out if the jdm tailights are the same as the stock ones and couldnt find anything. help? please. mine is a 89
RazoE;1442407 said:JDM taillights are the same as USDM taillights, the only difference is actually the paint on the center section, and the reflective plastic on the inside of the tails, not the outer housings..
JDM bulb holders DO NOT have the wiring for rear side markers, so you'd have to source a USDM set if you want to keep it all functional, but physically it'll plug in and work without a problem..
another thing, your taillights may come with hard, ribbed, plastic center trim instead of the USDM rubber, that is JDM only trim, and won't match anything USDM, but you can paint it easier (I have this trim on my JDM taillights)
92nsx;1445685 said:This might help. This is a pic I took of the difference. Long story short, I already had JDM's on my sup. but didnt find out till I bought another set of u.s. spec tails.
JDM is on the bottom
