MA717MGTE said:soo let me get this all correct and if you was doing it my way..
JDM 2J swap, USDM harness, ecu, maf, cams (or aftermarket upgrade) 550 injectors (but if i run single might as well go with somthing bigger) rrfpr, single manifold, Turbo (had concedered the Garret GT35) replacment dp, high flow cat (visual inspections here) catback (hpf 4") filter kit, piggy back management safcII or Emanage.
would that sum it up or what would ur set up be?
That is roughly what I will be doing, but I will probably stay at BPU with the stock turbochargers set to true twin conversion [TTC] for awhile, until I can afford a turbo kit, fuel system, stand-alone and tuning.
