well didnt get much of what I wanted to get done today because I got to play the valve shim game. finally got them all in spec and put the timing belt on. and I had to cut the AEM cam gear bolts also (about 2.5mm like IJ said).
one thing was troubling me though, when i put the cams on and then put the cam gears on and rotated them, it sounded like they (the cam or the cam gears not sure) were rubbing on something, looked everywhere but nothing, i think it was just the cam lobes hitting the shim/buckets, and yes I lubbed them good, then when i got the timining belt on and lined it up TDC the noise went away when I cranked the engine by hand....any thoughts?
