YOU SIR ARE NUTTY!
What SupraAng said might be your problem, yur WAY too rich... You might be dumping so much fuel that it's not buring properl;y and giving you a misfire, aka, the opposite of detonation... So much fuel you put the fire out... Are you running a stand alone? Or factory ecu? Pull some fuel and try again... You should be, well, this varies from member to memeber, but I would say, you should be about 11.5-12.5:1, you should get richer as the boost increases... So, lower rpm should be 12.5:1 and move into the 11's at you run up the rpm's...
Good luck...
BTW: how is compression? Hmmm? Is your tranny slipping?
Good luck...
