I've decided I'm running 4inch exhaust
Status
Not open for further replies.
DGmk3
DomesticMan sucks
May 15, 2006
122
Superior WI/(Duluth MN)
Ive found some stock and some bends of 4inch pipe at a local diesel shop and the price for the whole turboback is gonna be about $200 so here comes the volume I'll post a vid when it's all done..is anyone on here currently running 4inch??
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Yep, but it's not the made from shoddy bends at a muffle shop. Check out horsepowerfreaks.com's Goliath exhaust system. 4" MANDREL bent baby! I know of at least one member on here with it, he also posted a video of it on his car (it was one of the big HP guys on here, maybe Nate), I'm just too lazy to search it for ya.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Even if it WAS crush bent, it would be head and shoulders above a 3" mandrel system as long as the bends were kept to a minimum.
But he mentioned he found bends at a diesel shop, and they're always mandrel.
Go for it man, post up some HQ vids when you're done. It'll be awesome.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
On a turbo engine, the faster you can get the exhaust out, the better.
You may not NEED a 4" exhaust, but if you plan on making big power at some point, I'd just jump right to 4"
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
Exhaust is only as good as it's smallest restriction...so from 3" test to 4" the rest of the way back isn't going to do anything for you.
SupraB
Need 4 speed mods!
Jul 24, 2006
71
Spokane WA
rumptis said:
run DP only then :)
Im running DP only right now, and I hate it, all the sound is right under you, it smells, and it wants to backfire. plus i didn't notice any performance increase. That could be cuz im at stock boost though.
Anyway, Im gonna go 3" probably HKS or Tanabe as soo as I have the cash.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I'm running a cooleze down pipe with his test pipe... Nothing after that, I agree that it sounds like shit until you stomp it, then it sounds a lot like a DDP. I'm pretty sure that I'll lose some power when I finally get around to putting a cat back on, but I'll sacrafice a HP or two for better sound ;).
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
I'm running stock all the way back other then gutting the first 2 cats...it sucks but funds are major low...can't wait for tax time!
I will probably go Cooleeze or BIC DP, not sure yet about the rest other then it will be 3"
suprarich
Guest
Nov 9, 2005
2,187
ohio
You can get 6 inch mandrel bends at the diesel shop. Most of the larger trucks use 6 inch. Prob would rub the ground on most of our cars!
Status
