Here's a partial Mod list
• HKS Full Turbo System System includes Garret T04B 57 Trim Turbo
• HKS Exhaust Manifold and Down Pipe with External Waste Gate HKS F-Con Fuel Computer
• 3mm Steel Head Gasket
• 440cc Toyota injectors
• HKS Intercooler Kit which includes all piping
• HKS Super Sequential Blow Off Valve
• Cooleeze Custom made Intake Pipe
• HKS Power Flow Intake
• Modified AFM
• RC Engineering modified Throttle Body
• Edelbrock Water Injection kit
• HKS Oil Cooler Kit
• Horsepower Freaks Goliath Exhaust System
• Sun Auto Hyper Ground and Hyper Voltage Systems
• MSD 6A Ignition Box and Ignition Cables
• HKS Super Fire Iridium Spark Plugs
• HKS EVCIII with ATM Electronic Boost Controller
• HKS Turbo Timer
• Optima Red Top Battery relocated to spare tire well
• HKS 13lb. Chrome Moly Flywheel
• Center Force Custom DFX Clutch and Pressure Plate
• Custom Made Stainless Clutch Line
• Drive Shaft Shop Aluminum 1 piece Drive Shaft
• C’s Shifter with Razo Carbon Fiber Shift Knob
• HKS Hipermax Coilovers
• Suspension Techniques front and rear Sway Bars
• A-1 Racing adjustable Sway Bar End links
• A-1 Racing Traction Arms, Toe Rods and Camber Rods
• Greddy front and Cusco rear Strut Bars
• JIC Magic Lower Control Arm Tie Bar
• Jim King Front Brake Kit to include 4 Piston Wilwood Forged Billet Superlite Calipers and 13.1x1.25 drilled and slotted 2 piece rotors
• Precision Brakes Rear Brake Kit w/ 4 Piston Wilwood Forged Billet Dynalite Calipers and 12.8x.81 drilled and slotted 2 piece rotors
• Custom made Techna-Fit Stainless Steel Brake Lines
• Autopower Industries Street-Sport Roll Bar
• Sparco Flash 5 Steering Wheel
• HKB Steering Wheel Hub with cruise control buttons
• Sparco Torino Seats and Brackets
• Sparco Pedals
• Sparco 3” SFI Certified Harnesses with Cam Lock Buckles
• Sparco Fire Warrior Fire Extinguisher
• All Interior Panels reupholstered utilizing Sparco Black Jaquard Material with matching black carpet on lower door panels
• Custom Black 1A Auto form fitted carpet in front drivers compartment
• Custom matching rear carpet completing rear seat delete and extending through rear hatch area
• Custom made Leather Shift Boot and E-Brake Boot
• Autometer EGT, Boost, and Fuel Pressure gauges
• Knock Link and K&N AFR gauges
• Custom Hood Vents
• Kaminari Rear Spoiler
• Hella H-4 Headlight conversion with PIA bulbs
• Kosei Racing S5R Wheels, 17x9 rear and 17x8 front
• BFG G Force TA KDW Tires, 275x40x17 rear and 235x45x17 front
