Istrument cluster help?
Satan
Tampa
Sorry to "maybe" hijack... The sender that we use, seems VERY similar to the senders which are offered for aftermarket digital oil pressure displays. Has anyone in this thread tried using one of those aftermarket/universal displays with the stock sender?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Satan;1812497 said:
...The sender that we use, seems VERY similar to the senders which are offered for aftermarket digital oil pressure displays...
Very similar in what way? As 3p pointed out the stock sender is unique. It's designed to work with not only the stock gage (itself unique) but also the TCCS.
IBoughtASupra
4,455
Queens, NY
Jet, if I remember correctly, was it you that said the oil pressure signal is used to adjust engine RPM +/- 50 RPM?
This is in response to you saying its design for the stock TCCS.
Satan
Tampa
When I was looking at the digital oil pressure gauge (Autometer, I think), the accessory/optional sender, looked exactly like that on a 7M (which is why I did not buy the sender at the time, tho I ordered a different digital display). Just assumed it was a standard Toyota thing. Guess I can try it and see, then order theirs if necessary.
Satan
Tampa
Doublechecked last night... I got an Intellitronix gauge, which does require some 0-100 PSI digital sender (theirs for near $30). I need to finish my gauge cluster project soon :-/
