BryanDyer;1932376 said:I have a 57 trim only have it set to 15 lbs don't really wanna push it past that
what do you think my fuel pressure should be at?
I had it 35 got it tuned ran great but then started running rich so I dropped it to 31 and I'm gonna see how that effects it
BryanDyer;1932629 said:I think that is a cause but I can smell the gas from the exhaust when I'm driving and I wasn't sure if it was running that rich becuase I weather or if there was another contributing factor
BryanDyer;1932376 said:what do you think my fuel pressure should be at?
BryanDyer;1932640 said:yep but no wideband unfortunately...it's hooked up to the stock o2 sensor it says I'm rich but I know it's not to accurate but I can also smell it
I have the afc neo tuned but maybe the numbers are set wrong across
DeMoN2318;1932661 said:Wowzers!!! with no wideband how did they get the NEO tuned properly? With your mods you should definitely have a wideband.
If it all of a sudden started running rich then something obviously has changed...if the weather got warmer then you will run richer...but without a wideband its hard to tell if you are running rich or the fuel smell is from somewhere else
