89 Supra with 91 engine harness converted to 89 plugs where needed. T61 turbo, 3" DP, 440CC injectors, stock AFM, Apexi SAFC Neo, stock fuel pump, 2JZ FPR. Can't think of anything else.
Problem #1
Well first, yesterday it would sometimes die after taking it out of gear and I would start it back up and it would die again... Do that a couple times then it would idle fine. However it seems to be getting worse. Sometimes it would idle great then about 2 seconds later just die.
Problem #2:
I keep having to adjust low idle fuel between 650-950. The idle fluctuates here and there as well. When it fluctuates the AFRs change as well...
After it ran great for 30-60 minutes (enough to break in the rings) it started going pig rich. Like 10.0 (bottom of the UEGO reading) at 2,500-3,700 and it would misfire during heavy throttle like that. That's at -50 on the SAFC... It wasn't repsonding to SAFC changes at all.
The ONLY code that was thrown was code 11 which is Momentary interruption in power supply to ECU.
Trouble Area
* Ignition switch circuit
* Ignition switch
* Main relay circuit
* Main relay
* ECU
Other than that, it sounds amazing open DP and pulled really strongly up end the high end.
Any thoughts?
Thanks!!!!!!!!!!
-Nick-
Problem #1
Problem #2:
Trouble Area
* Ignition switch
* Main relay
* ECU
Any thoughts?
Thanks!!!!!!!!!!
-Nick-
