I posted not to long ago about an issue I had been having with my starter not engaging. I found it to be the ignition switch and it started right up, no questions asked. However this Friday it stopped starting once again. The same issue as before, starter will not engage and turn over. So I am currently lost and need some help!
Below is a list of things I have done so far, to try and fix this problem.
1. Replaced starter.
2. gutted out the alarm system.
3. grounded the blue and orange wire, and the two under the hood.
4. replaced the ignition switch.
I've checked fuses and wires. Made sure my grounds were good, I even cleaned the brown connection to the starter, and still, It will not start! If anyone has any suggestions then please, tell!
-Joe
-Joe
