My ISC does not make a sound either...it's a screw type actuator. If you want to test it, unplug it with the car running and idle stablized. This freezes it in the idle position. Remove and take a look to check position of the valve. Re-install and plug it back in, start car for a minute, turn off (plugged in) and remove. The valve should be at full open. I'll bet your ISC is fine. If you haven't already, you might as well clean it.
Idle on a turbo car is 650 rpm. Remember, you can't drive it without a check valve...it prevents boost back flow.
