It's been a bit of a crazy year, meant to post some updates earlier, but didn't get a chance to.
I did get the flywheel installed along with the new clutch disc. It feels fantastic, though I may still adjust it a bit, not sure yet. Much lighter makes for a more rev-happy experience, but it's not crazy light and so does still drive very smooth, as a Lexus should. Additionally I did replace the 3.91:1 Torsen T2 differential setup with a low mileage 4.10:1 T2 to give me a bit more gearing advantage and did a few other items here and there as well.
Original Dual-Mass Flywheel (120,000 km, 20k of which was with the 2GR-FSE), still in spec, but
heavy:
New Aisin NVR clutch disc beside previous TSB-updated clutch disc. More torque capacity:
GRMN clutch line/hose setup with no accumulator to replace my previous pieced-together setup:
4.10:1 Torsen T2 Limited Slip Differential:
In an effort to freshen-up but also increase a bit of the tight feeling of the car, I went ahead and replaced a few of the bushings/mounts on the car. I carefully considered which engine mounts to go with and
almost went with the Megan ones, but I just couldn't get enough confirmation about their characteristics to make the leap.
2GR/6MT engine mounts / GRMN transmission mount (stiffer than 4GR):
Replacement shifter bushings:
TRD differential mounts/stoppers (front upper/lower and rear solid rubber instead of liquid-filled):
IS-F rear subframe mounts (stiffer than ISx50 stuff):
Overall, the car feels fantastic at this point, I am still considering other ways to improve its performance, however now that I am back in school things will likely progress a bit slower.
Jeff
